I expect the lower teams are pushing for this to be banned, as it will cost them a lot to keep developing it when most of them are so far behind on it already. Should have been done before/after the season though really.
"The FIA's note will cause all teams, whether or not they use a blown floor, to change their operation," said Allison.
"The headline changes for the Silverstone GP are as follows: when the driver lifts his foot fully off the throttle pedal, then the ECU maps must be set up so that the engine [to all intents and purposes] closes the throttle - previously it was possible to configure the engine maps to leave the throttle open and reduce the engine power by other means.
"Furthermore, when the driver lifts fully off the throttle, the ECU maps must be configured to cut off the fuel supply to the engine – this is intended to prevent so called 'hot blowing' where the energy of the exhaust gas is increased by combustion."
Allison, whose team pioneered the radical forward-exit exhausts this year, conceded it was difficult to know how the changes will affect the performance of its car.
"It is not easy to judge the effect of this change on our competitiveness. The loss for each blown floor car will come from two separate effects – how much downforce will you lose and, in addition, how much will the loss of this downforce upset the balance of the car.
"All blown floor cars will lose downforce under braking as a result of these new restrictions. Some teams will lose more and some teams less; it is hard to know exactly what relative loss LRGP will suffer.
"However, it is possible that we will suffer less on the balance shift side of the equation because our forward exit exhausts produce their effect quite near the middle of the car. This means that as the exhaust blow waxes and wanes, it does not really disturb the aero balance of the car too much.
"With a rearward blower, the downforce from the exhaust is all generated at the rear axle. As the new rules reduce the blowing effect on corner entry much more than corner exit, it is possible that the rearward blowers will tend to suffer more nervousness under braking and more understeer on exit as a result of the new restrictions. We will find out in Silverstone."
"We would have preferred the status quo to remain for the rest of the season," Allison added.
I can't wait for silverstone. Itll be interesting to see how each team reacts. Although as I said before i still expect RBR dominance.
I will laugh from silverstone to xmas if Red Bulls race pace in relation to the rest causes a bigger gap, ...
But we all know the dream is to see a British driver win Silverstone, hopefully we will see McLaren turn it up to 11 and show RBR what 2 British world champions can do
Hoping this finally gets rid of RBR's advantage.
Hang on.
Theres a fundamental thing that has been missed here. I thought parc ferme rules meant you couldn't make any major chances to a cars setup at all between the start of qualifying and the start of the race?.
But yes, there may be the potential to have one of their maps on the steering wheel set to the Qualifying mode, and then switch it off. I don't think they could stop the teams changing engine settings from within the car, as they are used to cope with varying track conditions and fuel levels, etc.
It will be interesting to see the impact on RBR following this. If they suddenly lose all of their pace, it will certainly throw last years championship into question.
I really dislike the FIA, they make up the rules as they feel like it.
Like many ideas before it, it was very clever, but now the FIA have decided it is against the rules. Hard luck really.
