The phone has a resolution of 800x480, if you wanted to go that extra bit you could take a screenshot on your phone then use the image to make your new one from. That would allow you to factor in your dock bar and status and not lose any of the image when you apply it.
I done this but it doesn't let me select the whole picture?![]()
Dialler, *#*#4636#*#*
Battery History
Partial Wake Usage
Whats the top app?
MURDEROUS G What ROM is that with?
The battery is fine, but it all depends on what you do with the phone. If you only call and text, it should last a least 3 days maybe 5.
If you have the screen on all the time playing games, web browsing etc.. it'll last a day.
If you're listening to music, you'll get a couple of days out of it.
GPS - you'll get about 2-4 hours.
Lock the phone (i.e. push the power button to lock the screen) and leave it for a minute or two.
Go back and push one of the buttons at the bottom (Home, Menu or Back) and see if the screen turns on. If it does, then something is keeping it awake. The screen should never turn on from anything other than pushing the power/lock button at the top.
I wonder if you have a dodgy program on there or something, that might be accessing the internet or using GPS without you knowing.
Your battery temp is pretty high. Mine is sitting in an office that's about 24c and the temp listed for the battery is 28c.
Voltage at 99% charge is 4154mV - if yours isn't near that on a full charge it's got problems.
If you buy system monitor from the market it will monitor applications and tell you which ones are consuming cpu.
