android would have all the apps in the world open at once if hardware allowed that to be possible. you should not have to close any apps (definitely on a phone of this spec). if they are duff apps, report and remove it. task killers are evil!
Only on my old Nokia N97.
Has any phone ever had this built in?!
And my old N900, and most other Nokia phones Ive had lol
Point is you can stop all your apps you have finished with from running in back ground instead of having to pop into task manager to see what is still running..
in setting account and sync, click on google setting,
not sure on sound
my old lg arena has.Has any phone ever had this built in?!
Thanks dude I did that before but calendar kept giving me messages about how it can't sync with google calendar - I just ignored them this time and it worked
REALLY miss not being able to differentiate between getting an email and getting a text message - even my crappy ol ZTE Blade gave the option to have seperate notifications![]()
You can set notifications in the individual apps. For example, go into the stock email app, press menu and select account settings, scroll down and there is an option to change the ringtone. AFAIK, most of the communication apps have this, such as stock mail/messaging, Handcent, Go SMS, K9 Mail, etc.
what r u on about... the deal i posted which is the hottest deal of the week on hotukdeals
it is what it is!
£99 for the phone
12 month contract
£30 per month
400 cross network mintues
1000 texts
1gb web data
+£30 cash back
My maths makes it
Total for 12 months = £459.99
Quidco is also available -£30
so Total around = £429.99
you confuse me and yourself
why?
12 months rent is £120
24 months rent is £230
12 months is cheaper and hence the better deal.
Lol I give up.
i can get one second hand (only 2 weeks old) from someone for £340 should i go for it?
would need to shift the DHD for around £200 at a later date
What you are not grasping is the fact that after a 12 month contract you are free to go on a rolling sim only contract on any network and the cost for the next 12 months will be cheaper via this route than a 24 month contract.
Also consider the flexibility of being in contract for a shorter period of time.
