Who here owns a Fiesta ST?
19 Oct 2005
Kernow
Doing your superT's?
I still keep toying with the idea of going back to standard wheels but I don't think they would fit over the brakes, even with spacers.
It's driving me around the bend haha.
Would be doing my standard alloys. Think i'm going to put the idea on hold though. Want to get some factory style tints and it lowered first. Splashing out £80 on this paint is a bit too much at the moment. May as well put it towards getting them powder coated.
Think i may has a go at cleaning my throttle body too! Looks easy enough to do also.
OP
13 Jun 2007
Chesterfield
Rybo89 - I see that you have a cold air feed. Where have you situated that?
They was both pretty easy to fit. I left the air resonator brackets in place and just ripped out the resonator box. So then i had something to wrap the tie wraps around to keep the cold feeds nicely in place.
Also pierced holes on the end of the cold feeds so i could tie wrap them to the lower grill, just under the radiator.:
They work really well there aswell.
Will get some better pictures later of it.
18 Oct 2002
Sutton Coldfield, Birmingham
Theres where my cold air feed pipe goes, only problem was I had to trim off loads of clips from the front bumper for the intercooler to fit and guess what, the cold air feed for the mountune kit attaches to one of those clips!
Managed to secure it another way last night and it seems to of done the trick. You certainly notice it on a warm day though.
19 Oct 2005
Kernow
One thing that puts me off just getting a 57i is how ugly it looks in the engine bay. I think i'd probably get the mountune CAIS and even leave the standard airbox in situ above the engine block.
18 Oct 2002
Have you found out what offset your OZ's are yet :p
18 Oct 2002
By the way, anyone who has the 'starting' issue with there car, where it won't start sometimes until you poke the accelerator, then take your car to Ford and get them to install the latest ECU map on it.
Mine was an 06 plate and this happened quite a bit when I bought the car. Still happened even after the custom map from JamSport however when the charger kit was taken off and Pumabuild flashed the ECU back to standard, the issue has completely gone!
30 Jun 2010
UK
Yeah, that's exactly what I've done with mine. The standard airbox at least looks nice in the engine bay, even if it serves no other purpose once you've upgraded your air filter.
OP
13 Jun 2007
Chesterfield
It is still a must! Opens the engine up so much better, better acceleration, better response, O and sounds awesome.
Im not a fan of silly exhausts what make silly sounds but the K&N 57i makes a brilliant noise :)
24 Aug 2009
UK
Well Im looking to get a flexi pipe. Meant to make the car feel better to drive. Seen a nice one for less than a £100. An induction kit of some sort is a must on a ST. The noise is better when you floor it and seems to make the car better mpg wise.
19 Oct 2005
Kernow
They're in storage but i'm off to the place where they're stored today so i'll have a look for you! :)
Not had any problems starting mine. Only ever missed a beat once when i started the car and turned it off straight away then left it overnight.
What effect did the 57i have on your insurance? Depending on Rich's review of the Mountune CAIS i may get one of those. When i had a 57i on my old zetec for a bit it was nice that it wasn't loud all the time and only when you were feeling a bit spirited!
How are you finding the car since cleaning your throttle body?
Also interested in getting a flexi pipe. Just don't want to be taken as a mug for spending over £100 for what is just a larger flexi pipe. Anyone got a milltek/mongoose flexi? Any noticeable gains? Hard to fit?
OP
13 Jun 2007
Chesterfield
Had no effect on my insurance. Yeah the K&N 57i kit is brilliant, very quiet, well unless you are putting foot down and going over 3500 revs.
I cannot really comment on the Throttle body yet mate as i have to run it in for about 150-200 miles before the ECU adjusts to it.
24 Aug 2009
UK
No its not milltek its another popular make but not a lot of people know that this company makes one for a Fiesta. Im not going to say what it is cause I want to be different.
30 Jun 2010
UK
Eh?
All flexi's perform the same, what's different about yours apart from the name?
24 Aug 2009
UK
Nothing is different just the brand name is. Its not mongoose either. Im not saying its going to be better or works any differently either. Just saying that the part is a lot cheaper than a milltek and mongoose and might become popular which I dont want to happen.
