I cannot play games
OcUK Staff
12 Apr 2008
OcUK HQ
Tried playing Counter Strike Source, didn't work, and does the same in Portal too.
This is what happens:
http://vimeo.com/26484961
It seems very slow, unresponsive and just not working. :(
Any idea what this could be?
I have tried reinstalling the game, and even Steam itself, and the same happens. I am unsure as to why this is.
My spec:
Intel Core i5-2500K 3.30GHz @ 4.60Ghz
Gigabyte Z68X-UD4 Intel Z68 (Socket 1155) DDR3 Motherboard
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 1600MHz Dual Channel
Xigmatek Dark Knight CPU Cooler
Asus GeForce GTX 560Ti DirectCU II 1024MB GDDR5 PCI-Express Graphics Card
Corsair Professional Series AX750 Modular Power Supply
Intel 510 Series "Elmcrest" 120GB 2.5" SATA-3 Solid State Hard Drive
Asus Xonar D2X 7.1 PCI-E Sound Card
LG CH10LS20 10x BluRay-ROM / 16x DVD±RW Drive
i would try stock everything and maybe another hard drive hopefully you havent got a goosed component on your new build :(
I will try Minecraft to see if anything happens there. That is about the non-Steam game I have. :p
I believe the drivers are up-to-date:
I presume this is a fresh install of windows you've got problems on? Do you get the same problem with other non-source engine games?
Also, have you tried verifying game caches? (Should be fine after reinstalling the game, but worth checking for the minute or so it takes).
Sure is, new system, I have tried verifying game caches and defragment game files. Did not work. :(
Damn !
Oh well i tried lol
It is appreciated. :)
