You're being short changed, my 16gb sd + usb stick's are 15gb.it's normal. even a 16gb usb stick gives around 11gb..
I think the OS just eats a huge amount of space.
once 2.3.4 official is out is it going to be updated via Kies?
You're being short changed, my 16gb sd + usb stick's are 15gb.![]()
ping is bad right? you want as low number as possible.
i use auto brightness. no way could i be botehred to keep changing it when i go inside, outside etc. auto as well means it's as low as possible in middle of night.
Just noticed but why do i only have 11GB of storage when its advertised as 16GB? i know you never get the full 16GB due to how the file system is set up but 5GB short seems odd.
Any ideas?
The built in speakers for reminding myself of songs on the way to my gigs, or I sometimes connect it to my car system via the earphone socket. Via my sony MDR EX71 earphones with custom settings on the phone to increase bass, it's not bad at all. Only gripe is lack of volume through earphones compared to my ipod.
Hi try this to increase volume:Enter this number *#*#197328640#*#*
This will open the service mode menu.
Select option [5] AUDIO
Select option [1] (VOICE CALL)
Select option [2] HEADSET
Select option [1] Volume
Select option [1] SRC Speech RX Volume
Select option [5] 5_lvl : 87
Press the menu button (left side)
Choose Key Input
Enter a value between 0 and 100, with 100 the loudest setting.
Press ok
Then press the menu button and select back this will save (don't use the right side back key you normally use to navigate the phone or you will quit out of the settings).
Keep selecting the menu and back until you exit the service mode menu.
You will also note you can change volume settings for other things like Bluetooth, handsets, video call etc.![]()
I have a flash issue. Since I had to wipe my phone I get a update to the current version msg on BBC site. However I'm on 10.3. Is there an option somewhere in flash?
Yeah getting that too.
Edit: I read that deodexing 2.3.4 breaks hardware acceleration on the browser ...that might explain why watching flash video in the browser or Pulse force closes sometimes too.
