- 3 Oct 2009
- Wales
It's amazing how much difference a slightly padded floor makes to deadlifts. Feels like an extra 40kg on the bar
that gym looks good for free, only real thing that's missing is dumbbells i noticed the olympic dumbbells but they are dangerous when it comes to heavy weights, your never sure whether or not its going to hold or fall on top of you.
if i was you, i would start putting £20 in a jar every week then after a while get a set of iron masters if your really want to do dumbbell work
Other than the running machine giving you static shock and then cutting out
Freefaller: You want to imagine that the bar is static and that you are pushing the floor away from you.
...I'll get it one day
It's like £1 for 250g iirc.
