yeah I don't even own enough stuff to amount to £2000![]()
which is why it's a stupid idea
I also need to get some more SSD love. Going to get a 240gb
add another £260 onto the other total of £860, now you need to spend £1120that's at least £300 more than my whole pc when the parts were new!!
still £930!
I added the £70 to the £860 you already said
If I were you I'd get the newer EK HF cpu block, which I did![]()
block i'm getting said:EK-Supreme HF (Easy Mount) Nickel/Plexi water block
the block has a square top, it's the same one as the build in your sig
It says on the product description that it has bits for polishing and sanding.
I'm planning on cutting 1.7 mm thick aluminium. I'll also be getting some sort of ridiculously sharp, stabby thing to make some sort of a Mark first.
