Indeed, if that is the case start off ligther, try and get your body used to the range of motions it needs to do. It will help in the long run, and you won't cause more damage because of it! Last thing you want to do really.
It's the one reason I'm so cautious on shoulder / chest days really.
Annoying isn't it?
I think I just have to work out at say 85% rather than 95% and maybe save HIIT cardio stuff for non-weights days. Might right side can put up with it but the left is just not able (although the shoulder injury was due to sitting incorrectly on the bench and it does feel a bit better now).
On a side note I nearly put a barbell through a window today![]()
