Dont forget to do the webOS update. That will be another cup of tea right there.
That was the system update. I've added tea and snacks.
remember the state of apps is very poor. Unless android comes out or a lot of people start developing apps then this won't change.
however, one of those 2 outcomes will almost certainly happen now
Just to let you guys know that the Touchstone charger works perfectly with the official case, you just need to pay attention to the orientation of the tablet. The home button needs to be either at the bottom or to right as it's facing you, otherwise it won't charge.
Anyone know if there's an alternate browser? The standard one doesn't seem to support drop down menus or the ability to turn off auto complete. Also anyway to pair a Wii mote?
Had this running @ 1.728Ghz for hours and Govnah reports the battery temp @ 32oc, not too shabby maybe it can go 1.9-2.0Ghz?
honeycomb has less tablet apps then webos 3.0 has tablet apps.remember the state of apps is very poor. Unless android comes out or a lot of people start developing apps then this won't change.
Guess it depends on opinions I'm finding very little that I want or ones that are free (with potential android I don't want to pay yet).
Do you know if Android supports multi-touch at all? Or does it depend on what version it is?
Great service from CPW, not so great from Yodel whos tracking information still says its at the depot in England...Tbh I thought so but wasn't sure. Just looked up tech specs of a few android 3.0 tablets and they all support multi touch.
Therefore it would depend if the port of android supports it
Honeycomb doesn't need tablet specific apps because Android apps scale. So there are already thousands of apps that work perfectly in Honeycomb without needing any change.
Any apps that can stream from my computer to the tablet?
Anyone know of a decent office app. I can't find anything that will let me create a word document!
There are many apps that don't resize/scale correctly to 1280x800 in Honeycomb. They may work correctly but only look ok because they haven resized properly to the native resolution. There will be a fix to address this but it won’t fix them all. Honeycomb does need tablet apps and there are a number of specific tablet apps which display beautifully using the 1280x800 landscape resolution.
