intuitive isn't it.![]()
The gestures are miles better than a back button, yeah.
I did the maxblocker one yes, removed but still getting a black screen when I press play on the video. Maybe I'll try a cold boot.
EDIT: or I cold just read the instructions on that page properly.Will clear the cache etc as well.
EDIT2: that fixed it, thanks![]()
How are you watching 4od? When I try via the website I just get a black box now. Flash seems to work fine on iplayer etc. Did you do the tweaks in the link on the first page? 4od used to work when I was on stock 3.0.0 but when you went full screen the navigation bar used to obscure some of the middle of the screen.
http://img17.imageshack.us/img17/2846/redbridge2011082600009.jpg[IMG]
My 2 new cases just turned up, very nice[/quote]
Which case is that, have you managed to find the only third party one which doesn't cover the bezel?
(IMO of course).Eww you got a screen protector on that haven't you? Gorilla glass you know.. makes it ugly and pointless(IMO of course).
What? I meant until Honeycomb is working properly on the Touchpad. A normal version of 2.2/2.3 isn't going to be nicer than WebOS for me at least.
Next time post what you actually mean. It does help.![]()
I'm using Kalemsoft Media Player (Beta) on my tablet (found here - http://kalemsoft.com/betas/) and their server on my computer.
I'm not really sure how it works, all I know that it does work and is very quick. Once you select the avi on the tablet it opens up almost immediately.
It's worth trying. You need to install the beta through WebOS on your computer.
So one thing I'm confused about is I didn't appear to do anything but the software version is 3.0.2, is it now shipping with it as default.
Is there any decent genuinely free media player? I am surprised hp didn't bundle something themselves.
the power button of my touchpad is not working. I can not use it to lock the sceen, and turn off the touchpad. what should i do? i have already update it to 3.0.2.
