- 30 May 2009
- Maidenhead
detection skills helps prevent you from getting detected but are pointless once detected, the only thing that helps once you are detected is fortification. If you use fortify before being detected then its a bad idea and will most likely get you detected, but once you are detected there is nothing stopping you simultaniously fortifying everything between you and the firewall to slow the trace down, and since you are already detected there is no reason not to.
If I get detected though, I just pop a stop worm
And the game is orange tinted, not yellow tinted to whoever mentioned it
Seen this in action on a mates PS3, I want to buy it for pc, however, it is 49€ on steam
The augmented version (44€) is cheaper than the normal version on steam. The limited edition ''benelux'' version is 25€ retail...
Will a retail version register on steam (for the achievements)?
It's a Steamworks game, so it has to register on Steam. If it has achievements on Steam, and it's retail, then it's Steamworks.
Been mentioned a few times.
BTW does any know if any of the battery recharge augs actually recharge more then just the 1st battery?
Sadly not. If you don't use an entire cell, it will recharge. Like a few seconds of stealth. But otherwise you need to use the energy bars to refill other battery bars.
