- 27 Mar 2004
- Telford
edit
Difficult to know whether that would provide enough juice without it giving any specs. I have a generic plug with usb socket and when I try charging the touchpad with that, if i recall correctly i get a message saying something along the lines of there's not enough power to charge properly/quickly. No problems with the official plug though.
And the full international kit!
a 1.2amp (which I have) will still charge the touchpad though I think - obviously just not as fast as a 2A charger.
I'll probably buy the one I linked earlier.
EDIT - Robbo, seeing as you have an iPad can you test whether the ipad usb plug works ok with the touchpad (see if the ' not enough power' message pops up).
Device may not charge
Your device is connected to a charging source that provides less than the recommended voltage or current. To reliably charge, use the power adapter and USB cable for your device.
It doesn't work. Not enough power.
What I found strange about the kit that came with the touchstone was the the barrell shaped bit didn't seem to fit the plugs parts that came with it. It had 2 prongs that fold out but no way to hook it up to the plug heads. I had to plug the USB into the plug that came with the TP instead.
I thought that initially, you need to twist the end off . . . .![]()
more than 20 secs, even held it for over a min.
interesting as the ipad has a 2A (10W) charger.
*goes to check adapter left in box*
Ohhhhhh
*feels stupid*![]()
Is there a way of transferring files via wifi?
