correct
I am unsure what this stigma surrounding updating an SSD firmware is all about
updating the firmware is easy
DL the FW and burn the iso to disc
then ensure your sata mode is IDE in the bios [it should be set to AHCI so you will need to change this]
boot from your cd rom
wait for the utility to tell you that your m4 is detected and needs to be updated
type 'yes' by pressing the Y, E and S keys in that order
then press enter
walk to the oven to check if your pizza is done
then come back and see your drive has finished updating.
restart with CTRL+ALT+DEL
enter bios and change SATA mode back to AHCI
then sit back in your chair and say, "woah, that was pretty easy. I dont know what I was making all that fuss about. It took less than 5 minutes of my time and now my drive is 1/5th faster than it was before."
then sit there with a smug grin on your face knowing that your SSD update was really easy and the people who bought an agility 3 are having massive problems.
unlike yourself.
