For AM3 that is correct, i over counted the pin holes on my AM3 Crosshair 4 Formula. So, if i want to go Bulldozer i'm gonna have to upgrade to a Socket 942 motherboard. Looking forward to the reviews.It's 941 pins.
Sorry that was my fault i over counted the pin holes. If one thinks about it, it actually states on the motherboard i took that photo of ...Socket 941, so therefore 941 pin holes, lol. So, no bulldozer on this AM3 mobo for me.AMD release it already so am not sat here counting holes![]()
But one might be significanly faster than the other in certain computing scenarios?.It's a CPU, it will do what BD does either slightly slower or slightly faster.![]()
I just recounted all the pin holes in the socket and i now make it 941. So how is a 942 pin cpu going to fit into a 941 pin socket?.
211 pin holes in the green.
306 in red
244 in blue
180 in black
lol - not sure that'll be a problem - who knows - we have no idea how much stock will be in the supply chain
BUT I suppose you could always pre-order - and (not that you have to) - leave boxed - and you'll have 7 days to return anyway if you chnage your mind after reviews come out
I'm REALLY hoping for this range of CPU-s to be a good-un as I fancy a change to AMD![]()
Are you saying there'll be no reviews until the day people can walk away with it from a shop?
That's a bit unfortunate if so. Plenty of people like me will buy it anyway, but will want to know results and how they compare between AM3 and AM3+ ... especially those with the CHIV like me and so many others.
On this note, does anyone reckon the 12+2 phases of the top AsRock board will offer a major advantage in OC'ing?
I am not saying anything about reviews, just that benchmarks come out at launch.
Ah, right. You meant AMD issued benchmarks. With you now.
Are you able to tell us how long before release the NDA expires? 10 days? 2 weeks? 1 week?
..Buying on Day 1 blind is foolish. Utterly foolish - Because as much as there is a chance it will be 128918291x faster than anything else in Scenario 1 it might be shockingly bad in Scenario 2...
What about me? I dont want to spend my money supporting (way too big) Intel. I know Im going to get the AMD on my next system and I don care if its loosing some battles. Hmm.. dont care if it loses all of the scenarios. Its still going to be AMD all the way for me. From this point of view, its not foolish. Not for me.
As someone who has only built with AMD and currently has a Phenom II and two 6970's it still sounds a little foolish.
would you do the same when buying a car ? please don't say so ...
Someone bring back cyrix lolSomeone bring back cyrix lol
