- 31 May 2009
me too!
arrggh
arrggh
How do I get my hot bar buttons back? They keep hiding themselves when not being used!
Its not just you, i was very thorough and I didnt max the pistol damage and ROF. I actually gave up on it as it could still perform OHKOs on enemies and instead focused on the heavy rifle which is much more useful for bosses. I could have maxed it if i didnt focus on the rifle I suppose(which i didnt max either). I still picked up loads of reload mods, some of which i didnt use.
I thought the plasma rifle was pretty amusing, you get it right near the end and you can put plenty of upgrades on it but by that point you dont have anything to upgrade it with and may as well stick with the heavy rifle.
Have to agree with what you said about the rocket launcher, it doesnt even destroy the big mechs with one shot which means emp grenades will always be better as they require minimal inventory space by comparison
I also agree with what was mentioned earlier about the battery charging, I have no idea why they decided it should only charge the first point as it makes putting extra praxis points in cells pointless. I still put points into it near the end anyway as I had praxis coming out of my ears
Does anyone know many bonus points do you get for ghosting an area? I've never even come close to managing it as its too much hassle and i dont bother with putting points into stealth earlier on
Since the availability of energy bars makes the lack of recharging batteries pretty much a non issue, I think it's most likely they did it as a way of further restricting inventory space. They could have easily ditched the energy bars and had full battery recharge for the same effect, but then it's quite obvious inventory is intentionally limited.
One thing I would change is the fully upgraded inventory should just have been standard, because even then space quickly becomes valuable and you're forced to make choices on which play style you want to lean towards. I think I'd have been annoyed at having to drop things I wanted to keep every 5 minutes if I'd not put praxis points into inventory, as it was the balance was decent enough. I still dropped plenty I'd have liked to have kept, but then I'm sure the idea is very much if you want to see that stuff, play it again.
^^ I had a funny one on a boss fight (one of the harder ones) I'd hacked a turret a few rooms back so was dragging it along with me - came out the elevator carrying it without realising it was a boss fight and after the cutscene the turret and the boss went at it at each other and I just sat in a corner out the way til the turret killed the boss lol.
TW78wbN-WuU
Pretty inspiring stuff.
Indeed and absolutely fascinating as well. The men and women making and using these prosthetics now are, as said in the video, pioneers of our future as a species. It's a shame though that so much of the advancement in the field has been as a result of war. From the subjects requiring prosthetics, to the technology that goes into the manufacturing of the prosthetics.
