Eidos still aint fixed the stuttering/fps drop bug yet, useless nobs
Sorry, I had to laugh, just the way I it sounded in my head as the words greeted me.
Hopefully a patch will be out soon, then it'll be fixed by the time I get round to playing it.
 (you get a steam achievemnet for it as well
 (you get a steam achievemnet for it as well )
Does anyone happen to have a full list of achievments, including the hidden ones. I'm 37/49 but only 5 of the remaining 12 are visable for me. I tried doing a mission a different way, such as the bad way to end the mission for the bartender at the hive in the hope that would give me an achievement but I got nothing, so my initial assumption of the hidden achievements are alternate endings to missions may not be right.
-----------spoilier-----------------
if you didn't destroy any robots does that mean you let malik die?
as i didn't think there was any other way of disabling that robot thats dropped off?
It was well worth waiting until the end of the credits, if just to hear the Deus Ex theme(you get a steam achievemnet for it as well
Awesome tune - I loved the random civilians whistling it!
I've just started a Deus Ex play through to continue the story!
One thing i would have liked is after each ending there would have been a follow up showing how the world react changed and was then manipulated by others to become the deus ex world.
I went for the destroy the place option.
Whats the general forum consensus on this then, worth getting? Reviews are very positive.
Well maybe if this is as successful and popular as it seems to be then they might make another one
I felt that as well, also thought it was a bit odd that there was no follow-up with Dr Reed(until the credits kind of did)
I thought about it but wasn't sure if you would die also, but in the end i thought i'm definitely going to play it again so i'll do that then probably.
I missed out 3 side missions it seems according to Steam achievements(although it might just be the way that i did them as opposed to not doing them) I didn't get the achievement for "Follow Pritchard's lead" but i did do a bit of it so probably just didn't do what was needed to get the achievement. Same for "deal with the man in the shadows".
Steam says i was playing for 26 hours. I don't know if it counts offline properly though as apparently i've only played 5 hours of Morrowind, but i have completed it!
I have been playing it side by side with HR with New Vision and Biomod. absolutely brilliant, i finished it the other day. Biomod is excellent as it changes the way Augs are used very well imo
Yeah you do.
Biomod?
I'd hope any new deus ex game would be a sequel to deus ex not another prequel
