Yup the Stealth has cherry brownsLoving it so far, had to get the US layout though
Can't you use the macro software to change the affected keys into UK symbols. Maybe ask razer for some UK key caps from the ulitmate keyboards
Can't you use the macro software to change the affected keys into UK symbols. Maybe ask razer for some UK key caps from the ulitmate keyboards![]()
Yup, @ key is changed in software, only big change with US KB's is the backslash key which is now above the enter.
For the money this is probably the cheapest and only way you will get Cherry Browns in the UK
I have an Qpad MK-80 and my brother has a Zowie Celeritas, I really like the Celeritas for gaming, but because of the amount of typing I do, I prefer the Mk-80.
The MX brown switches are very good, probably the closest to rubber dome keyboards like the G-19, so the transition should be very easy for you.
I'm seriously considering getting one of these now. I have been using a wireless HP super flat keyboard, which is very nice to game and type on. It uses scissor switches so much better feel than rubber dome. Only problem is that because its wireless its not ideal for gaming and sometimes lags. Also the batteries don't seem to last long at all and they have ran out mid game a few times now.
Went back to my old Hiper rubber dome keyboard and it felt like typing on jelly.
Are mechanical switches at all similar to scissor switches? how much more travel do they have compared? Really like the feel of scissor switches but if mechanical are better then i'd rather get one of them.
Doesn't the MK-80 use Cherry blues?
How do you know it has Cherry Brown switches?
The travel in most cases is double on mechanical keyboards compared to scissor, plus mechanical keyboards don't have any bounce to them. I think you would be best with a Cherry brown switch, the feedback is sort of similar to scissor switch, but you get the benefits of mechanical, like long term durability.
Why? They have a lighter, quieter and shorter keystroke than domes and last a lot longer. For me they feel really nice to type on, although i don't do a lot of typing. For FPS gaming they are much better for me with the shorter keystroke.Scissors are practically worse than domes...
It says on their website
Yeah I noticed they had a US layout only so I'm holding out on the purchase at the moment. I sent in a question about it but the guys at the store didn't know so they forwarded it on. I have yet to receive another response about it though!
Edit: the problem with the US layout is the fact that the enter key is far smaller and the backslash key has moved! I much prefer the UK layout.
Edit2: The main thing attracting me to the black widow is the matte look and the lights.. My room is poorly lit because I have brown vertical blinds and I have them closed constantly.
Just get a USB lamp on your desk. I have one, it's LED and can be set fairly dim over the keys if that is what you want.
I have a Noppoo choc mini mechanical, with cherry browns. It's a very nice keyboard, lovely to type on and great for gaming. The keys are printed with dark print, which looks really nice but means they are invisible in the dark. I was planning to learn to touch type, I am about 80% there - so sometimes have to flick on the lamp.
It says on their website![]()
Is that on the Cherry website, or the Razer website? I couldn't see it on the product page
I *might* wait until I can order a UK layout WASD keyboard. But not sure. Still not certain on blacks or browns, will definitely need to test them![]()
Ordered the new Blackwidow Stealth from Razer, should be here tomorrow. Matte finish and no more clicky keys, sounds perfect...I hope
