I7 2600k over clocked using asrock fatality m/b
Odd just booted into windows and loaded f stream and CPU speed is fluctuation between 1600mhz x16.0 to 37000mhz x37
thats because speed step is enabled and c state
With the core current limit why a big jump as with a 4500 oc was set at100 but with 4700mhz oc. Set to 230
i was told it helps with booting up, iv not really understood what it does so i asked on a forum and a coulpe said set it at 140 and a few said 230.
i will google it and try to give you a definative answer
will do it now... just did a windows expiance index refesh cpu went from 7.6 to 7.8 grr if i could only get 7.9 for perfect score but would need to oc ram also as thats as 7.8
rebooting to try now in bios
well after 1 min it dropped from 4700 down to 4000 its now at 3900 core voltage 1.304v its about 30 mins in .
maybe this is the reason cant be oc past 4ghz????? dont see why not tho
