- 14 Apr 2004
- UK
You guys have to get Quell HD. Fantasticly addictive
It's a risk, there are a number of threads on the net with users complaining that their TP has image retention after extended exhibition mode use. Some have got rid of it after a bit of pixel cycling others have had to rma.Really?![]()
my targus case arrived from amazon today - nice case and tight squeeze, but seems to be ok.
The speakers are covered, but can still hear them fine.
The power and volume buttons are part hidden, but still very usable.
The only downside is the weight, but then my TP does feel very secure and safe.
I'll have a play with a soldering iron later to see if I can free up the speakers, but it's not really necessary.
The battery will age either way but assuming the touchpad has good float charging capabilities then as long as you occasionally use the touchpad properly every now and then then it shouldn't be much of a problem.Won't the constant trickle charging damage battery life too?
You won't harm the tablet or the touchstone but you do run the risk of image retention or screen burn on the display.
Hello, 1994 just called and wants it scaremongering back.
Any idea how to save bookmarks?
ThanksPress the bookmark button in the browser (top right, square icon with an arrow coming out of it).
Random symbols = pet hate. I had the same problem trying to work out which of the symbols was reply to an email. The OS needs an option to change symbols to text. Shouldn't need to have to look at a manual to find out how to do stuff.
Actually, there are various reports of screen burn on some of the newer phones out, so why would this be any different? Does screen burn just mean the screen is faulty or something then?
i would be massively suprised if you had image retention on an IPS or AMOLED screen. You just won't.
Which seller did you buy it from?
Does it look like this? Because the blue looks slightly different than the one on amazon.
http://forums.precentral.net/hp-touchpad-accessories/295659-ipad-truss-case-stand.html
Yes, that's the same, but the blue is more vivid. I haven't bothered doing any mods in the end as i've not needed to. The volume and power are slightly impeded, but still easily usable, and the speakers being hidden doesn't seem to be a problem.
Annoyances for me so far, any workarounds?
- No home page in browser
- No storing of passwords in the browser
- Rubbish bookmark icons (image from target page) with no way to customise them
- No way to organise bookmarks
- No way to switch between Facebook accounts in the Facebook app
