does the cd contain the latest chipset etc drivers? or do we need to d/l any updated versions?
coolwhats the software called?
not at my pc now its in the utility part i think on disk somthing software package its under![]()
Thanks for the heads up, ill check it out tomorrow
I was thinking the same earlier unfortunately the drivers on the site dont have a release date so have to compare after loading from CD drivers. Im gonna check tomorrow hopefully and let you know.
have you set your boards up?
no not yet, as I mentioned still undecided on ram. tempted by the ripjawx as they're so cheap(~£73 for 2x 8gb kits), but not sure about the fins interfering with the arctic freezer 7 pro rev2.
I'd suggest getting a better cooler than the arctic freezer 7 pro rev2
Just to add, there are a couple of software versions and drivers on Asrock's site that are more up-to-date than those on the CD. There is also a new bios version. Asrock's servers are very fast so it shouldn't take long to download if you've got a decent internet connection.
@Fowler can give me the model number of the ram your looking at buying? looking at the arctic reviews the fan tends to cover the memory slot but there is a gap underneath the fan question is how much. i can use my own E7 as a reference point and try get a arctic template based on the measurements.
check this link out hope it helps http://www.thermalright.com/new_a_page/product_page/cpu/venomous-x/memory_compatibly.html
Ill take a look when I get home I think you might just be ok, do you know if the cooler can be fitted with the fan pointing in the opposite direction?
thanks for your help but the price of the ripjawx has gone up to £43.56 for 8gb(so 2 kits ~£87) at the place I was looking.
I can see them where I bought my memory from at £36.31 for the 8GB set.
but postage is £5.70 bringing it to £42, so now corsair vengence lp or kingston hyperx genesis grey?
just looking on the asrock website at the drivers(not check cd yet), a least for the chipset inf utility they have an older version(ver:9.2.0.1021) than on the intel website(ver:9.2.0.1030) does it make a big difference?
