Hamster others are having this issue with USB devices too. Deathadder and Xai also cause the issues, can only presume it needs a bios update but i dont think ones out for it yet :s
I'm having issues with my phone plugged in via usb where i get a 'B4' error and the pc hangs before loading windows. When i disconnect the phone, the pc continues into windows. I'm, pretty sure I got a similar problem with an external drive plugged into the e-sata port.
Disable usb legacy in bios and it will boot ok.. Had that prob with the extreme4 still no fix..
Oh thanks btw
Just tried that and now I regret not having installed the PS2 bracket!! With legacy usb disabled, the keyboard wasn't active until windows started so had to clear the BIOS and start again, damn you![]()
Mine arrives tomorrow along with a whole host of other new toys, extremely excited.
Hoping to push the 2600K to around the 4.8 Ghz mark, anybody have some advice as to the settings they're using?
Cheers
only thing i had to do was go in to memory settings and change the memory from auto to xmp profile 1 for the ram to work at 1866, everything seems to be working fine
Cheers
Cheers[/QUOTE
its easy just auto clock it in bios to 4.8, don't need to do anything else apart from what Mr V said about ram profile, if you overclock with a standard cooler the cpu temp will be about the same in windows unless you stress test all cores as the cpu idle is about the same as when at default clock speeds to overclocked![]()
Got mine up and running at long last after some back and forth drama.
Seems stable at 4.8 but going to leave Prime running overnight to be 100% sure.
Had the issue with the mouse causing the PC not to boot so had to disable Legacy USB support, this now means that I can't get into UEFI to flash the damn Crucial M4 to the new firmware, so looks like there is a CMOS reset coming soon.
Also, will not boot if my Drobo is connected (via eSATA) which is going to be a massive issue for me if that doesnt get fixed soon. At the moment I simply disconnect it when the PC is booting and plug it in once I see the Windows log in screen, short term solution until something better comes along.
hmm the esta issue doesn't sound good as I have a hdd caddy with 2x 1tb samsung f3.
on my current system on vista I was able to plug it in while windows was running and it would 'pick it up' and I could eject when done but after installing win7 have to have it connected at bootup and can't eject it(not sure if its something in win7 thats different from vista or I have to change a setting somewhere).
I have £40 now for ram from selling the 2 deus ex codes I got for buying the 6950s![]()
which version of prime are you using?
surprised by the esata issue, i was looking at a 5tb raid5 esata DAS will hold off for the time being. thanks mate
Crezzlin, are you prime stable at 4.8? My board won't even boot at 4.8 with the auto setting.
Any reviews of this board yet?
