Legend. Thanks Bruce. I'll give those cartomisers a blast![]()
Don't forget to order a 510 driptip for them.
The caps on these cartomisers are pretty crap. Just fling them and attach the driptip.
I guess that's the rub for me: I want something as simple as a tank, but with the kind of vape you get from other bits of hardware.
That, Im begining to think, is the holy grail of vaping..
First cartomisers arrived yesterday - should they be so noisy? Im talking rice crispies noisy, snap, crackle and pop type thing?
I ordered
Boge Low Resistance Cartomiser
Boge Standard Resistance Cartomiser
Dual Coil XL Cartomiser Resistance : 1.5ohm - Low
ClearoCartos - 1.5ml - Resistance : Low - 2.4-2.6 ohm
Im using one of the cartomisers, but I don't know which one as they all look the same and there was no labelling. Gives a hell of a throat hit though
As for the cheap ClearoCartos - how do you fill them?
I took the o-ring out from the top and dripped into it, and most of it came out the other end. Im guessing that the wicks need to be wet, but should there be fluid visible as well, or is just getting the wicks wet enough???
Im using one the following at the moment
Fill them with a syringe, don't you? Pull out the rubber o-ring that is the mouth pice, and you should see one or two small airholes. Poke your syringe through one of those to fill.
Hey guys, does anyone know what the average life of a Tornado Tank atty is,
Reason for asking is, well mine seems to have stopped working completely, battery is fully charged and theres juice in the tank, but nothing :|
anyone spec me a nice new one, looked on the TW site but can't see anything that remotely looks similar to what i think i need lol
Thanks for the replies.
I think I am probably just putting a little too much pressure on an straight transistion from the coffin nails to better health, having tried all manner of cessation aids which invariably make me gag.
The PG/VG business did have me scratching my head, so I think I'll get another order in tomorrow now that I have a bit more info under my belt and perhaps try and avoid replicating my regular smoking experience.
