One thing I do find odd - climate control on modern BMWs. They're crap. What's the point of having a temperature controlled climate where you can also have different temperature air coming in through the manual control fo some random wheel in the middle of the dash.
Set temp at 20 deg, but then adjust temp by changing the mix of hot/external air.
It doesn't make any sense.
If I set it to 20deg I want the cabin at 20deg surely?
I have literally spent half this thread explaining exactly why this little feature is so amazing. Effectively it gives you the option to immediatly change the air to suit your taste at that moment whilst leaving the core settings intact. Just because you are a bit hot and bothered doesn't mean you want the entire car to be 16c. You just want a quick blast of cold air. Just because its snowing outside and you've just got back in doesn't mean you want the car to be a 32c Sauna. You just want a quick blast of hot air..
, I just find it a confusingly pointless system. Unlike any other car I've owned, without any real benefit to it.
