So i'm stuck, the M4 i have installed works great and i have no problems. But it's on 0002 and my Bios only have options for ACHI or RAID. Is there a work around?
PS - i get 7.4 on mine as well.
Would i have to start from scratch and install windows 7 again afterwards?
Crucial make the M4's in house so to speak, they also provide their Micron nand chips too, Micron is a sister company to Crucial, and yeah they also update their own firmware in house.M4 64GB
I guess it's because Marvel only provide the controller & don't actually write the firmware unlike the Sandforce SSD's.
Looking into purchasing either the 64/128gb Crucial M4 but I'm not sure on how it'll perform with my mobo. Currently got an i7 920/Asus P6TD Deluxe (Sata II)/6gb DDR3/5870 etc - from what I've read my mobo has the Marvel controller which I've heard doesn't like to cooperate very well with SSD's?
Could anyone share any light on this? Would love to purchase one whilst they're on offer!
Not sure what size to go for either. OS will be on it obviously, possibly a couple games but that's it. Music etc will be on my 1TB Caviar Black.
Thanks in advance.
if its the marvel 9128 controller you have then its capped at 400mb same as mine but is still silly fast and when i upgrade mobo in future its like a free ssd upgrade aswell...... happy days![]()
Southbridge
6 xSATA 3 Gb/s ports
Intel Matrix Storage Technology Support RAID 0,1,5,10
Marvell 88SE6111
1 xUltraDMA 133/100/66 for up to 2 PATA devices
1 xExternal SATA 3.0 Gb/s port (SATA On-the-Go)
your board has this on the marvell controller
Marvell 88SE6111
so it looks like its got external sata3 but no internal so 280-290mb you will get with your sata 2 chipset
Is it worth upgrading to 0009 if you're running an M4 on a SATA II board?
To cut through all the confusion here...Looking into purchasing either the 64/128gb Crucial M4 but I'm not sure on how it'll perform with my mobo. Currently got an i7 920/Asus P6TD Deluxe (Sata II)/6gb DDR3/5870 etc - from what I've read my mobo has the Marvel controller which I've heard doesn't like to cooperate very well with SSD's?
Thanks in advance.
