Our R30 firmware includes the following changes:
1. Adds the Modem Mode feature.
2. Incorporates fixes for lock-ups (where the Super Hub appears unresponsive to traffic and the admin pages are unavailable) and reloads (where the Super Hub would reload for no apparent reason) while under heavy load in 2.4 and 5 GHz wireless modes. These symptoms were caused by a memory leak in the 2.4GHz and 5GHz wireless driver. As part of these fixes we've changed the number of channels available under 5GHz to 4.
...taken from here
just wondering anyone got Wake up on lan working over the internet ??
Thanks,
Just got my new firmware set upSo far so good. Modem Mode with Dlink DIR-615 (with DD-WRT), seems to be working pretty well!
Mine too. I am thinking of getting an Asus RTN56U router to replace the DIR615.
Anyone have the Asus, and if so is it any good, the range on my DIR615 while better than the super hub is still a bit hit and miss, I was hoping the Asus will improve it.
If I was you, I would look at wireless bridging so you can still use your current router. Then perhaps put the second router near the edge of the range to extend the signal, not all routers come with this functionality so try and get one that you can flash dd-wrt on.
Yes.
Successfully turned my machine on from sleep via my android the other day using the Unified Remote app. It will NOT turn your machine on from off state though... not sure what is required to do that.
Got magic packet turned on under my network adapter settings, that was all that was required afaik.
