they haven't got the code from google required and never will do, afaik
More significant progress on the CM android port, hardware video acceleration and totally fixed sound.
just remember though they arent replacing webos with android but will be making it dual boot so you can easily swap between webos and android. Best of both worlds!
Didn't eject my Touchpad when in USB mode (just pulled the cable) and it says "OWWWW. That hurts!"
I lol'ed.
Same xD
Which site do you register the touchpad on for the HP store discount?
Would like to see if I can pick up a touchstone with a decent discount
It's been keeping the missus amused quite well so far
Just need to find out which is the best eReader for it.
Meh, TBH unless they can add cards into Android I'm almost certainly going to stick to WebOS. I love the true multitasking on the tablet. Hopefully the talk of running Android apps in WebOS will come to fruition shortly.
And the one major downside is that you lose any proper desktop and the widgets that Android provides.
Only reason I care about a Android OS is if we get the market. I don't really see the point otherwise.
This sounds like an ideal solution... or is there a downside to it somewhere?
I realise that it is not actually available now, but it doesn't look as it will be too long before it is!![]()
Can I ask why? not trying to be awkward I'm just truly 'meh' about the 'proper' multitasking in WebOS,
I've got an SGS2 so use that daily, and just open an app as and when I want, the state is saved and there's never any delay on opening an app so it's seamless as to whether it was truly active in the background or not. If I want to see running apps I can, same as closing them (although it's awkward I admit).
What do the cards offer above that? It's nice animations but that's about all I can think of right nowAnd the one major downside is that you lose any proper desktop and the widgets that Android provides.
Saying all that, I think it should be possible to write something similar to the card-style launcher if they someone was bored enough, guess you'd lose the bit about actually seeing what's in the app without being in it, kinda![]()
Can somebody please help me with my Kalemsoft streaming?
Widgets are pretty much taken care of by the top left corner (rotation, brightness, wifi etc.)
The cards offer the ability to have several things open and easily accessable. For example you can click on a game and leave it loading in the background while you quickly check an email. The implimentation just makes it so much nicer than any version of Android I have tried for me at least.
The ability to swipe up and slide across to the open app is something that still makes me go "wow", it's almost like working on an actual computer, especially useful when you want to check something from one card and input it into another.
I do like the fact you can customise Android (if you can be bothered) to look as you want but other than that IMO WebOS just betters it in almost every other way (discounting apps), same with WP (post Mango at least).
On the other hand I will certainly try ICS on the device if it ever gets ported, just can't see the point in sticking a phone OS on it! In all truthfulness the only reason I bought a touchpad was because it was cheap and I will hopefully be able to run Win8 on it when that comes out.![]()
I think the advantage of cards is that you can see which apps you have open, and easily move between them. It feels more like windows, you manually open/close apps, move between cards/windows etc.
The problem is that the web browser starts unloading pages when you get 3+ cards (or even fewer if you have really large pages), and I don't generally have that many cards open that I need to look at or switch between anyway.
So the Android approach of actually leaving the app "open" or cached, is just as good if not better, because you can access apps from your homescreen/widgets/recently opened apps, but Android decides when to actually unload the app. The alternative browsers have their own inbuilt tab functions too.
