Cruicial M4 0009 Firmware Update
I am trying to find out how big will be improvement in speeds if i will put m4 128gb drive in my MSI GX660R 15.6" WLED TFT Intel I5-460M, 6GB DDR3, 1TB HDD (2x500gb in raid0), ATI HD 5870 1GB GDDR5 laptop.
My sequencial read speeds from raid0 are only 104 MB/s at the moment. How much aprox. i will get with M4 upgrade?
I'm getting 237MB/s from my single 64Gb M4 in my older Sony Vaio which is only SATA-II so I'd imagine your speeds would be greater still.
That's not even factoring in that you'd RAID them!
I'm not sure what speed SATAII will limit it at, however you will still notice a massive difference in speed IMO.
009; M4 256GB; SATAII; EVGA x58
Bought a 128GB one of these a few weeks ago and they seem to have dropped massively in price! Oh well :(
Quick question though: I've got it installed in my netbook (HP mini 311c - Atom 270) and the 4k speeds seem slow, even with all C-states disabled in my BIOS. I'll post a bench up later but off the top of my head, they're around 16 read/22 write in CrystalDiskMark. Its a Sata II controller and the processor is perhaps a little slow to get the full juice out of this thing but surely I could get it running a bit better?
It certainly feels fast, but at the end of the day, no-one can ignore a benchmark :P
Does anyone else happen to be running one of these in a 311?
Edit: It's running 0009, too.
Edit2: SS of a bench;
Going to buy one of these in a few weeks, should I buy 2 64gb and have one for the OS and the other for games, or just get the 128gb?
I could be wrong but I think the 128 write speed is better than the 64? As we don't defrag these things I can't think of a good performance reason to have 2 rather than 1. Of course, if one dies you still have the other and you don't lose everything. And a 128 should be cheaper GB/£ than 2x64s
I was able to get the 2 x 64GB M4 Raid up and running in a RAID-0 Array and below are the results. (Stripe Size was 32KB)
System:
  • i2500k CPU running at 4.2Ghz overclocked (stock volts)
  • 2 x 64GB Crucial M4 SSD's running firmware 0009
  • 8GB Kingston PC10666 DDR3 Ram (HyperX Blu)
  • Gigabyte SoC GTX460 1GB Graphics Card
  • MSI P67-G45 B3 Motherboard running latest beta bios.
  • Antex TX650W Power Supply
  • Antec 300 Case
I purchased the 64gb version after my vertex 2 gave me a bsod !
I have updated the firmware on the day i received the ssd. My write speed does not seem to be around 180 -200 that most people are getting, i am on around 105.
Read speed is around 514.
Any ideas what is with the slow write speeds?
Those speeds are normal for the 64GB drive.
Hi
Asus P6X58D-E with crappy Marvell controller!
I reckon it is set up OK (M4 and 0009 firmware), plus latest drivers I can find from stationware drivers.
Does that look about the best I can realistically expect from my SSD bearing in mind it's hobbled by the Marvell controller?
I was able to tweak the RAID setup of the 2 x 64GB M4's and was able to squeeze out some better numbers than I got before.
System:
  • Antec 300 Case
With the overwhelming information in your post, I've come to the conclusion that I have absolutely no idea.
all i was trying to ask was would I notice a large improvement updating the firmwarre on a machine with the drive connected on sata 2 instead of Sata 3? Pretty simple question I would have thought for someone who might be in the know :S
