Big Bike Thread
Status
Not open for further replies.
My school *might* be signing up to a cycle to work scheme which means i get to buy a bike of a value up to £1k, pay for it over the course of a year from my paycheque and to top it all off it's taken off before tax is applied so i could end up saving around 20%. I'm cycling to work 3/4 days a week at present but it's on a 5-10 year old £300 (new price) bike that has seen better days. The suspension is soft was warm butter so whenever i try to really put some effort into pedalling i just end up bouncing up and down!
So yeah, anyone got a recommendation for a bike to commute to work with and, if i ever get the chance, for the occasional recreational ride? Maximum budget £1k, ideally i'd like a hybrid as i'd like to take it off of roads occasionally (but nothing cool like jumping and stuff like some of you lot do) unless there's some form of road bike i simply must have within that price bracket.
The floor is yours gentlemen, what's a good bike?
Thanks, it rides nicely too. It's a much better riding position for me than my GT Avalanche Expert, I seem to sit in the bike rather than on top. Being 6ft5 I was resigned to the fact that most bikes would be slightly uncomfortable for me, but so far this seems very comfortable.
Both rotors are rubbing slightly on the pads - not sure if they just need bedding in or whether I should reset the calipers. Think I'l leave it for a few days and see how it goes. Also, the front brake cable seems a bit long ... can't be arsed bleeding them yet so I'll leave as is and hope it doesn't get caught in a branch!
Both rotors are rubbing slightly on the pads - not sure if they just need bedding in or whether I should reset the calipers. Think I'l leave it for a few days and se how it goes.
Loosen the calipers, pull the brake lever then tighten them back up, unless your discs are warped it should sort it.
As Coocoocachoo said, the best is just to loosten the bolts that keep your brakes in place to the mount, wiggle the brake caliper around a bit, spin the wheel and grab the brake lever to stop( without letting the brake lever or blade).
You then slowly fasten one bolt a tad, then the other, alternating until they are both fastened. There will always be a little bit of running in the beginning, but that should go away very quickly.
Struggling to find anywhere that sells Cotic stuff in London. The only dealer they list is in Brixton and they don't seem to actually list it on their website. They also don't supply through the cyclescheme on their own website so i'm running out of ideas as to how to get my hands on one!
front disc is sorted, but now when I try and wheelie I here/feel a click somewhere in the front, like something isn't tight enough. I've checked and tightened everything in the stem/bars/front wheel but it still does it.
Any ideas?
Well today i had me first proper outing to Linkare on the push bike.
Did originally take both wheels off going to the place but couldn't be arsed we hassle when taking it home, so left them both on lol:
Map of the place, I went round all 3 reservoirs and through woods and then back on my self:
Pic of the bike:
All in all, it went quite well for first time in 8 years or so. Still struggling with the hills, but will soon sort it. Managed to ride through a massive pile of ****, what someone must have forgotten to pick up.... O and didn't fall off, but suppose i was going real soft we it all.
Should all soon come back though i hope.
Thanks but unfortunately my nearest dealer is in brixton and doesn't seem to stock them anymore. Reading has some but its a massive trek. To top it all off I can't fit it in my car!
Must have a tiny car... I can fit my barn door of a bike in the back of the Mazda 2....
Status
