AFAIK the cars are split between the old 2.0 NA 'S2000' Spec and the new WTCC spec 1.6 litre turbo engines?
Thing is, despite all the Plato moaning, does he have a point? I don't follow BTCC endlessly but it did seem at the beginning of the season that the turbo cars had way too much of an advantage over the others? What are the rules giving the engine options? i always thought BTCC had pretty similar specs for each team to use in terms of total power, engine spec etc?
They should just force everybody on the to the new WTCC spec 1.6 turbo engines and be done with it IMO. Put an end to the debate and arguments about weight penalities etc..
I find Plato/Neal almost as bad as each other, even though they are excellent drivers, although since Neal's pit antics at Rockingham I think he has dropped down my list just that bit further. Frustration maybe, but threats of violence are way beyond acceptable. Did he get any penalties for that?
The tyres on the Honda punctured in race 1 due to the sidewalls collapsing, not because of a brush with a kerb, or debris, but because of the weight of the cars.
This is on both Honda's.
I was on track at 1pm BTW.![]()
No. The BTCC is moving to a new spec called NGTC in order to try and reduce costs and attract more privateer runners to the series. There is extensive use of standardised parts and the NGTC engine is a 2.0 turbo. The manufacturer can either make their own or use a standard TOCA badged engine supplied by Swindon at a fixed price.
The performance issues have occured from a compromise that allows the teams to run NGTC engines in an existing S2000 chassis to help ease into the new rules for (I think) 2013.
BTCC NGTC will be a completely different formula from the WTCC. The Swedish series is also moving across to NGTC rules as well.
Thing is, the current compromise is just alienating fans.
They would have been better to force a start date, but given the teams 2 years to prepare for the changes, and possibly even helped pay for test days etc.. to help them switch.
I really hope Sheddon wins.
