!!**Official RAGE Thread**!!
played it since release @ 2560x1440 60fps all maxed out , had a few long load warm up issues but never any crashes looks amazing in places , for £23 i'm very happy
wow...Creating the "id software/rage" folders in "c:/users/(name)/appdata/local/" has eliminated nearly all of the stuttering I was getting! How could id have missed this?
Some of the game looks so washed, vsync is always on, I tried both nvidia forcing and ingame, game doesn't feel right simple as that.
Mouse sensitivity varies in different menus of the game such as quests, game looks awful and just does not feel right. I tried the nvidia cfg tweak didn't change much.
From now on only PC exclusive titles for me, I am tired of this ****
Tried disabling forced vsync and/or triple buffering? Tried the safe_mode tweak?
Disabled tripple buffering and now it's loading. Thank you :)
weird though as im sure iv not changed that since i 1st played it. unless the updated driver changed it. Going to try my saves now to see if it still crashes as i go into the mission area. Did it every single time before the update, fingers crossed.
***edit***
Just tried the savegame out and that is now working. unfortunately the performance of the game has taken a serious hit, framerates have drastically dropped to the point of almost lagging across the screen and fighting enemies is a no-go. I did revert back to the 11.9 drivers so this could be the cause. Ill try the latest ones and see how that goes.
After that last update its running alright. Textures look god damn awful when close up though =/. ahh well least its running alright.
So that's about 2 games a year for you to play then.
I have to disagree with anyone who says the game looks awful. Yes, there are some low resolution texture in the game, but as you are playing the game you really do not notice and as such it looks great.
As for the texture pop in, there are loads of games out there that suffer from exactly the same problems. Crysis, a PC exclusive, suffers from texture pop in and object pop in, as does BFBC2. Even Half Life 2 and the episodes has object pop in.
Has anyone got this to work with a 4980?
The best I can get is the game running at 50fps for 0.5 second, followed by several seconds of hanging.
Or, if I disable catalyst AI I get constant 50fps with horrendous artifacts! running 11.10prev2, added "id software/rage" to the appdata folder.
This games running perfectly on the m11x. Getting the hump :)
Patch worked a treat, though textures look terrible close up.
Loving the game, usually I skip a lot of the speech in these games, but Rage as quality script and actors for a change.
Was going to buy this but now after reading all this no way.
If you have a tri or quad core setup with an nVidia card it will probably work fine. Dual cores suffer from being unable to allocate enough CPU time to texture paging as well as doing game logic, rendering backend, etc. and AMD are still tail spinning on the driver front.
actually the whole only pc exclusive from now on is a bit too far, I had a blast playing space marine...juts have to restrain myself from pre-ordering from now on :D
:p
Resized from 1920
This seems like a good game but think I am going to wait till its patched up and working nicely :) So depressing the state that games are released in these days.
I have a similar rig but have a 6870 instead and since i started using the new 11.10 drivers and the new patch it runs very smooth and at a constant 60fps, a massive leap from before the driver update and patch.
Has anyone with an SLI config noticed that the CUDA transcoding option in the in game graphics menu has now disappeared. Yesterday it was there and my 1st card was doing the CUDA transcoding stuff, and the 2nd card was rendering the game, now there is no load at all on the 1st card and the texture pop seems to be back a bit. But the game now looks a little better.
Is anyone else getting this problem? It's like a filter that keeps cutting in every so often... unplayable on the 11.10 v2 with patch now. FFS!
Another point, if all the issues were driver related why has the patch fixed the glitching and texture pop-up for many people?
Carmack full of **** perhaps.
