****The Official Samsung Galaxy S II ACCESSORIES Thread***
Which is the best 32GB memory card to get or do they all work the same?
Currently looking at:
32GB SanDisk (4) micro SD HC - £33.14 delivered
or
PNY 32GB Micro SD HC Memory Card / Class 4 - £29.99 delivered
or
both will be pretty much the same - I have the sandisk one above.
both write speeds are similar - you dont have to worry about IOPS as i'm guessing all you'll be using it for is storing music/photos/vids.
Didn't realise 32GB micro SD cards were so cheap now. Very tempted to pick one up!
Found it for £25 including free delivery too.
70% after 20hrs? **** yeah :D
Extended battery ***! I'm on the 3rd full charge from 0% now. It has improved each charge so far.
Gonna order me the extended battery kit for the white GS2 as soon as its available and a 32GB memory card. I have tested out some PS and SNES roms and they are great. Is it possible to connect an actual controller to this beast somehow? :P
If you use cyanogenmod7 you can connect ps3 and Wii controllers. On the stock rom you can only use knock off pads. Check out ps1 and n64 emulation too.
Ordered a 32GB memory card.
Kreeeee, if I was to get a micro USB to USB converter for the S2, can I plug in a standard USB pad (or even PS3 pad via wire) and will it work?
I have so far tested out PS1 and SNES roms, will get onto the N64 roms too as that is one console I missed out on.
Most won't work like that because those pads require more power over USB than what a phone can delivery over USB-HOST.
Kreeeee, if I was to get a micro USB to USB converter for the S2, can I plug in a standard USB pad (or even PS3 pad via wire) and will it work? I am on the custom rom.
Nope, only a select few devices with with the USB host controller.
When you say you are on the custom ROM, what do you mean?
Ah ok.
It's not been rooted is what I meant.
You said earlier I can use cyanogenmod7, what is that and does it mean I can use a PS3 controller wirelessly on any emulator I install on the phone??
I've had a read through most of this thread but couldnt see anything about the "Case-Mate Barely There" case for the S2 - is this a decent case??
For my Desire I had a small neoprene pouch with an android popping its head up - is the same available for the S2 as its a bit bigger than the Desire!
Thanks guys.....
Thanks guys.....
I've got a neoprene case on order from the auction place. I'm hoping it'll be here by the end of the week - will post pics when it arrives.
Thanks! Would like to see how the S2 fits - I've tried it in my Desire's case and its too short and too tight!
Would someone like my SGS2 case for free? First to post gets it. I can try and post it tomorrow or more likely friday. :) I've not used it apart from fitting the phone in it when I first got it, otherwise it's just been sitting here. I prefer to keep the phone in it's TPU case in my pocket.
