***The iOS 5 Thread***
I'd expect iOS5 to start showing it's face tomorrow at around 6pm. I'd also love it to be available from midnight of course, but that's not been the case with previous iOS updates, and bear in mind it'll still be the 11th in the US then...
seem to be eating through my data allowance faster.. 50MB gone in little more than a day..
Depends on what you were doing with your phone really, and if it was any different than usual. Also, you've got to remember that every time you bring down the notification center, it reloads the widgets, so if you've got a lot of stocks or you're checking it often; it'll use more.
Could also be Diagnostics & Usage. Settings -> General -> About -> Diagnostics & Usage -> press Don't Send.
I remember hearing about that using data and causing excess battery drain.
Ok thanks, just turned that and the stocks widget off :)
