I don't think anyone is saying the performance will be terrible, but if you look online they are talking about how much of the UI and other tasks is being offloaded to the GPU. Here's a link to Anandtech testing various current GPUs; http://www.anandtech.com/show/4686/samsung-galaxy-s-2-international-review-the-best-redefined/17 Don't get too excited by the first two graphs showing geometry tests, read the whole thing through and you'll see the Mali-400 is pretty much twice as fast as the SGX540 in common uses. That difference is only going to be compounded when you consider the resolution of the SGS2 vs the SGN. An 800x480 screen has 384000 pixels, 1280x720 is 921600, 2.4 times as many. Tbh I'm half tempted to wait out this generation with an HTC Sensation instead.
Well that is how it is coming across to me
And finally someone else posting with evidence backing their points up!
Yes true that, but surely when you load a game up and more resources are needed then most of the power of the GPU etc. will go to the game not the UI or some background apps? The background apps will be closed in order to give more power.
Can't argue with those points really.
If the battery and camera do turn out to be better than the GS2 then it'll probably sway me to the GN, can't decide between the two at the moment. I was just hoping for this to be a step up overall from the GS2, at the moment it seems to be an upgrade in some areas (screen, current android version, etc), and possibly a downgrade in others (GPU definitely, probably battery and camera).
Once the reviews come out we'll see if the plus points outweigh the negatives.
TBH I reckon the battery will be better, since it is stock android and a clean OS, you don't have any touchwiz/sense stuff on top of android or tweaked and no other unnecessary apps therefore less resources which in theory should mean less battery life required and plus the CPU and GPU isn't as powerful but then you have the res of the GN, which will drain the battery but again look at the iphone 4 and 4s, they have the best battery life for a smartphone and they have a high res screen as well.
Please take a look at this in depth video before further spam. Already 3 man pages, mostly full of Nexus18 defending the old tech used in this phone![]()
CBA typing any more
In all honesty google have done a xxxxxxxxx good job with ics, so impressed with it and guess what!? I was a massive fan of choice and replacing everything with third party apps as they were always so much better, however with ICS in all honesty I don't think I would replace anything at all, just looks great and is amazing looking
Also the mobile to me looked extremely quick and exceptionally smooth, I didn't see one bit of lag at all and the screen is just jaw dropping.
EDIT:
The camera looks very good as well, I reckon even if the quality overall isn't as good, the features (granted the GS 2 will get ICS at some point as well) and quick snappiness of it will be enough to warrant over the slightly better quality camera on the GS 2.
