Wait until page file ruins your SSD and then say that.
Before posting rubbish try doing some reading on how ssd's work.
yes C:\ drive is my SSD but I've been told to move it to a mechanical drive (the first partition on the next drive) as the constant read/write will mess up my SSD.
This true so far as SSDs lifespan is determined by the number of writes. When SSDs first came out, TRIM didn't work, so people moved their page file to reduce the number of writes.
Assuming your SSD is configured properly and TRIM works...
It's no longer a problem - so putting your pagefile on your mechanical drive is simply slowing your system down unnecessarily.
I checked it by typing that thing in CMD. What else do I need to configure? . I'll move it back to my C:\ drive but what size should I set it to? I have 4GB of ram. Or should I leave it to system managed?I have TRIM workingI checked it by typing that thing in CMD. I'll move it back to my C:\ drive but what size should I set it to? I have 4GB of ram. Or should I leave it to system managed?
You should leave it to system managed.
The option to set it to a fixed size is for mechanical drives where it's better to have a defragmented page file. Defragmentation is unnecessary for SSDs because there are no moving parts - you should actually have defragmentation turned off because it causes writes for absolutely no benefit.
Yes I disabled the defrag service and windows serach service (indexing) through services.msc. Should I turn off super fetch aswell?
Managed to get all the old CAP's removed via safe mode, did a fresh install of 11.10 with CAP4, its now sitting like so with the preset of 'ultra'.
GPU1: 99%
GPU2: 98%
Memory: 2199MB
FPS: 90-115
Still get the stutter on mouse movement but I'll have a play later today to get rid of that, very very happy with my 6950's![]()
Just rolled my drivers back to 285.38. much better performance.
Don't ssd's have a bit extra memory allocated to level out any wear over time?
I get that stutter on a single 6950 tried allsorts even dropping res so framerates are 75-100 and its still there. think its the game and how it interprets the mouse movements.
Can't really tell elrasho.
I would have thought you should have your page file on C: if that's your SSD.
