What components make up your watercooling loop m8 ?
Thanks
I have this kit: http://www.overclockers.co.uk/showproduct.php?prodid=WC-042-OE
Thanks
Nice results Bulldog...did you get your chip stable at 5Ghz? ANd what was your max OC?
Just finished my Z68\ 2700K setup. Not powered her up yet though - little bit nervous![]()
yes my 5GHz is stable but @ 1.48v at the bios. Temperature around 28-87c
Jesus, does it need so much!?? I was trying to hit 5Ghz with 1.42v lol, but tbh my [email protected] (loaded) seems relatively sane![]()
I been hitting 5.4GHz @ 1.61v (only 20 seconds stable)![]()
So is the general agreement that the 2700k is worth it over the 2600? Or is it not enough extra for the price?
Max prime stable speed (minimum 1hr) - 5000MHz
Max booting into windows speed - 5400MHz
Motherboard - Asus Maximum Formula with BIOS set to AUTO mainly, just multiplier and vcore used.
Cooler - OcUK H2Flo with two fans
Memory - Kingston Genesis 8GB Kit
The H80 could definitely do 5GHZ if that's what your asking.
The cooler Gibbo used is basically an unbranded H80
temps maxed at 71C using Corsair H50 single fan. Ran 10 runs of IBT and all is fine. Not sure if temp is to high as first time since 486DX days that I have used Intelcan anyone one let me know what good temps would be for 5ghz overclock?![]()
