I store my nandroid backup on my windows PC as it's usually a large file, you can always mount USB from within cwm's menu.
Anything else you'd recommend?
What keyboard do you guys use? Other than the Samsung one? Any recommendations?
usb jig. 99p from china, allows you to boot into Odin recovery, gets rid of the warning triangle at boot, resets the binary counter and will make it appear like you've never used a custom kernel should you send it away for repair.
Right... Then my mission this weekend is to stick on a custom ROM.
Recommendations? Don't really know where to look or what is out there.
I keep meaning to order one of these but haven't got round to it yet. I do indeed have a little yellow triangle on boot![]()
Yeah but what if you want to try out a new ROM or restore from a backup if something goes wrong when you're not at home![]()
One ROM I had GPS issues in London so I restored a backup of a working ROM there and then via CWM and all was good.
Will it not be easier this time as the Galaxy Nexus has all the same (and more) hardware features as the SGS2.
I think the main thing that doesn't work with all these 2.3 ROMS is the HDMI output (I guess because this is not part of 2.3 Open Source Code but is added by some manufacturers), but they can just use the code from the GN as that has HDMI output as well?
I suppose a better way to explain it would be the Nexus S came with 2.3 and that was very easy to get onto the generic GS due to similar hardware/drivers etc. So the same would maybe apply for getting 4.0 from a GN > GS2?
rp2000
