On what hardware?Just tried the No FPS drop - FXAA PPI mod, i think it looks very good, i went with the low saturation one. No change in FPS(which are crap anyway!)
I desperately need to improve my FPS, outside of cities i get a pretty much constant 50-60 fps, but inside cities i get anywhere from 15-50fps and it fluctuates all the time
On what hardware?
I get 60fps whilst recording on decent but not top end hardware.
x4 965be
8gb ram
6950 2gb
I have to think it is a driver issue tbh.
Is there a level cap removal mod yet?
could maybe add the fov line to your ini or an autoexec and then make it read only.
Well considering there is no level cap, i assume this mod would be pretty useless, hence nobody making one.
Sounds similar to mine, though I've no idea what an x4 965be isx4 965be
8gb ram
6950 2gb
. I have an i5 and the same graphics card.There is a hardcap.Well considering there is no level cap, i assume this mod would be pretty useless, hence nobody making one.
Sounds similar to mine, though I've no idea what an x4 965be is. I have an i5 and the same graphics card.
Christ!!
You guys really do play this game on some crazy brightness levels.
To get the true experience you need to turn your brightness all the way down.
Then its a 1000x better.
Phenom quad core @3.4ghz, they say that the game is cpu dependent but i can't believe it makes that much difference surely?
Nude females... I hope I'm not the only one that thinks that's pretty sad!![]()
It's only a matter of time before we see the 'gynaecologist' mod.
