The Elder Scrolls V: Skyrim - MODS & TWEAKS
Just tried the No FPS drop - FXAA PPI mod, i think it looks very good, i went with the low saturation one. No change in FPS(which are crap anyway!)
I desperately need to improve my FPS, outside of cities i get a pretty much constant 50-60 fps, but inside cities i get anywhere from 15-50fps and it fluctuates all the time
It's a BEAUTIFUL mod, i've edited the OP as installing it incorrectly could mean much much lower frame rates
Im using the other FXAA injector mod too, and it stops afterburner from working :(
I cant monitor FPS or record anything using Afterburner with these injector mods.
It hasn't made any difference to me FPS-wise, I only get around 20fps in citeis no matter what i do anyway. AA, AF, Shadows, nothing makes any difference:(
Which one are you using Neil, Low saturation or normal?
It doesn't stop afterburner from working for me, just the OSD, which i don't use anyway.
Afterburner STILL WORKS
Afterburner OSD Doesn't :(
Pighardia, sorted out the frames looks amazing will edit the list :D oh and bhavv use Fraps just temporary
Christ!!
You guys really do play this game on some crazy brightness levels.
To get the true experience you need to turn your brightness all the way down.
Then its a 1000x better.
Eh no this is on default gamma on a highly hardware calibrated monitor, I can't turn the brightness all the way down or it makes me ill(vertigo) concentrating on dark screens while gaming.
Another FOV fix
* Create a backup of the skyrim.ini file * Open the file, then scroll down to where it says [General] * At the bottom of this section, add fdefaultfov=XX (where XX is the FOV value you want to change to) * Save, exit, and play
That is what i have done as it wouldn't stay as a console command.
I think that this isn't far off the best looking game i have ever seen tbh, and we haven't even got High-res textures yet.
How far is fShadowDistance=2500.0000 ? Just mine was at 8000 by default and I'd like to get the non pixelated shadows but not sure I'd like to only have shadows on stuff in the immediate vicinity if that's the case.
The Fov thing worked at first but as soon as I reloaded an auto save, the fov was messed up and i'm sure going inside and back out again from a location again fov messed up. Could be wrong, but something keeps defaulting it
I just set it manually when I enter the game, the ini file settings never worked for me either.
