I'd love to install some of these MODS but I can't get them to work, the windowless MOD would be fantastic, and I'd love to try out some of the graphical ones.
Any help? I've tried but it just results in the game crashing as soon as it's launched![]()
what you guys think of my newly textured dresser
i dont know why but something makes me think the games simple bland textures look better than high res, its like the high res textures just look messy?
thats 4x higher res than the default one btw but infaltes the file size from 1300kb to just over 5000kb :S, the same texture set is used on a couple of different furniture peices though which i guess kind of makes up for the size
you can replace what is already there but thats about it until they release the proper modding tools.It looks too saturated and too noisy and uniform to me. I think it might be a case of if you change one texture you have to change them all.
Is there a way of getting textures, models out of the game yet(without an external program like dxripper). Want to check them them out for reference.
I'm tempted to have a go at making some weapons and things.
you keep all the template lines that way and dont need to redraw thembtw for anyone who missed it when someone posted it a few pages back
the best FXAA mod so far
http://www.skyrimnexus.com/downloads/file.php?id=598
it makes everything look much more realistic and detailed than the other fxaa versions that are popular
- I think it is failing to connect to the server, then just crashing.A pretty nice enb config with different colour palettes / levels of sharpening and other effects.
http://www.skyrimnexus.com/downloads/file.php?id=822
