Delvis I think (using my rather uneducated brain) that you failed because you don't go low enough when you do 65kg.
Since lowering my weight and going lower than parallel I have noticed a huge difference! It's much harder and feels like I'm working the legs properly.
Thanks, will see what next Monday brings, although i'm borderline parallel I thought...Never mind, shall go lower next time.
injury's dont come from trying hard m8 you had mentally given up before parallel (in my opinion). crappy paint diagram to show my point on form (remember im not the worlds best form scrutinizer)
although i shouldnt be critiquing you really
It's not lack of trying, it's lack of having a spotter, it's a mental thing, I've had 70kg's drop on to me before with no spot, ended up with a massive graze down my neck. I've also screwed my shoulder permanently, from training 'hard, so yes, you can injure yourself from trying.
I'm all for criticism, hence why I posted the videos, I just like to understand the criticism, that is all.
Going by your drawing however (Which is awesome btw
) my upper back is 'arched' backwards...From what i've read, and been told loads, this is correct? You are supposed to push your chest out?
This is where it annoys me (not you), I read and get told different things. Then people say 'Don't over think it', yet if you do that you end up with poor form or end up inuring yourself.
Thank you though, i'll look in to it all and see what can be changed
