 - 19 Dec 2010
Anyone with an SB-E fancy running this, I would but don't have my CPU yet.
	nice to still be the fastest Phenom II quad![]()
 How the hell you manage that pal.....????
I can only get mine upto 3840, ( mind you, I hav`nt changed anything else apart from the multiplier, standard voltage.) Can you give me the specs to try on mine ... or is it .. you could .. but you`d have to kill me after..![]()
Revo.
	3930K @4.8
RAM bottleneck? idk.
. slang I know.!My Ram is
CORSAIR VENGEANCE 12GB (3X4GB) DDR3 PC3-12800C9 1600MHZ TRIPLE CHANNEL KIT.
I don't know why Insane Dutch Killers would effect my pc.
have you tried nailing the timings right down? IE is your ram running at 800Mhz with Cas 9 timings?, timings do have quite a large effect on the results in this one![]()
well the timings look about right tbh, but 675Mhz is slow, you need to manually select DDR3-1600 in your ram speed options in Bios to get them running properly imo, can't help any more because i'm not familiar with your board or it's settings lol
	Was some quite good little battles going on at one point.
