Will keep doing the knee stretchesAnd the glute ones
I believe i'm doing them romanian style, as I find it uses the right muscles more for me...But i'll try swapping them after Squats, see what happens.
My leg day consists of:
SLDL's
Squats
Leg extensions*
Leg raises*
Calve raises
*The above two are using an attachment on the end of a bench like this:
Works well for me at the moment.
I've tried lunges prior using a barbell, nearly went through the windowI'll have to look up some of the other exercises, never even heard of them
And no, don't play any sports. Oly thing I used to do on a daily basis was Skateboard, but that seems to have just screwed my knees up among other things (which is a different story)
I'm not even sure what this word means, but it's scary![]()
It might be worth you looking into some plyometrics or a sport which involves explosive movement.
Try the leg routine I suggested, although do lunges with DBs. Isolating your hams and quads with leg curls and extensions won't help you at this point.
And Jestar, that's my philosophy too. Strength > aesthetics for me, but not to the extent that lose all definition.
