So glad to hear they're releasing support for upto 4GB.
Yeah, me too. I haven't installed any mods because I don't want to break anything mid-way through a playthrough. But I hope this will get rid of some lag spikes.
Has skyrim updated today?
I now get a "The system cannot find the file specified" message when trying to launch the 4gbpatch exe.
Same for me, the latest patch improved it slightly but it is still terrible, drops to around 25-30. Before the patch it went down to aroun 15 though!
I can't seem to find what causes it either, i can look at 2 (apparently) identical screens but get 60fps on one and 20fps on the other, the only thing i have noticed is that shadows make a hell of a lot of difference in some places.
Here is a link i found whilst searching for a solution myself( i had it bookmarked)
http://www.tomshardware.co.uk/forum/332396-15-6950-issues-skyrim-possible-solution-inside
It is only for AMD cards though. There are probably similar ones for Nvidia carsd if you have one.
Something is going on though, as some people play the game flawlessly with weaker CPU and GPU's
What water mod is that? Or can you give a list of mods?
Started using the mod manager.
One question do I need to tick update.esm in the plugins tab?
Does anyone have the Potions mod as it seems to have gone from the skyrimnexus website?
It might've already been linked, but is there anything to stop guards being less... er... psychic?
Delete TESV.exe.4gb in your Skyrim folder.
- 1.4 is meant to include the LAA fix though, fingers crossed!So glad to hear they're releasing support for upto 4GB.
New patch, broken 4gb fix- 1.4 is meant to include the LAA fix though, fingers crossed!
Where can I get the 4gb exe?
I have been using this one http://www.skyrimnexus.com/downloads/file.php?id=1013
It doesn't work for me with the new patch though![]()
*sigh*
Read a few posts above, you have to delete the TESV.exe.4gb file and run through the Skyrim 4GB exe so that it can rebuild this file using the latest game executable.
It's been asked a number of times in the Comments section of that mod too so not much you have to do really to find out. And it's certainly easier than posting here and waiting for an angry reply from me.![]()
No need to be so grumpy about it! I had never heard of the "TESV.exe.4gb", so didn't realise it put that in the Skyrim folder. There are quite a few LAA fixes out there too, so didn't realise it applied to the one I am using. Geez.
Bad night.![]()
- think I will just wait for the next patch.
