Not a bad price for a backlit mechanical keyboard, the Flico (non backlit) with Blacks (Majestouch, NKR, Linear Action) is £120 (tho its possible to get it for £99).
Been playing with the Ozone Strike this week but probably going to go with the Flico in the end as it seems a bit better, tho that Mionix is tempting to try to.
Thanks,They are as good as they are made out to be, yes, but it's still down to personal preferance. Some people will still prefer rubber domes. Do you really need a numpad? Having the extra space between the mouse and keyboard is amoung the best things for me about my Filco Tenkeyless (only surpassed by the switch). I would recommend a Filco as they are brilliant in every way, they are expensive, but you get what you pay for.
As far as switch type goes, Brown is the safest to go for unless you can try the others before buying.
Thanks,
I guess for the amount I use the numpad, no really. Just never used the other number buttons.
And sorry, what exactly is this 'brown'?
Thanks for that, clears things up.Cherry MX Brown, the type of mechanical switch. For Filco you can get them in 4-5 different switch types, most common ones being brown, black and blue.
Read this for a good starter
http://www.overclock.net/t/491752/mechanical-keyboard-guide#post_6009482
Personally I have Brown switches and find them good for anything.
Where do people even buy these keyboards from then? OCUK don't seem to stock any Filco ones![]()
Cheers, now the decision.
UK Filco Majestouch-2, NKR, Tactile Action Keyboard
or
UK Filco Majestouch-2, Tenkeyless, NKR, Tactile Action, Keyboard
Hmm!
£40 though, might as well just go for the keyboard which has it built in.. Sure I can live without it and get used to using the numbers under the F keys.You can buy the numpad seperately if you need it. Personally I need a numberpad when I type any sort of number.
Filco if you want the rolls royce of mech boards.
I'm still waiting for a UK Filco Ninja Majestouch-2 Tenkeyless with Cherry MX Browns. Should be around next year apparently. If OcUK can stock them at a good price that'd be...![]()
