- 3 Oct 2009
- Wales
Did you ask the guy to move?![]()
Twice, both times he said he was using the rack and would be done soon
Then I suggest repeatedly introducing the 20kg DB to his face with great force.![]()
Does anyone else seem to tail off in Autumn/Winter?
Was going 4 times a week to the gym, running 3 times a week and cycling 5 times a week, since October just binned it and been gym a 4 times every month
Skillmister, regarding core work...
If you search for something like "core exercises" under my username you'll find a list of stuff I'd normally recommend.
But also, read through this: http://www.t-nation.com/free_online...ning_performance_repair/lower_back_savers&cr=
I haven't looked at it fully, but it's by Eric Cressey (awesomeness) and he references Stuart McGill (god of back health).
Out of curiosity If there was the possibility to do a work out before the start of work and after would it be beneficial ? I'm reading mixed reviews some saying yes some saying no. The intention would be to mix the muscle groups , trying to increase in size ( Diet is a major factor here understandably so a lot will depend on this!)
It wouldn't just be 25 reps of squats a week, there would be an additional 25 reps of leg pressing as well.Ok, but 25 reps of squats per week is not enough! Look at how much work you're giving the rest of your body, to then only put that much into your legs is criminal.
Looks awkward to me to be honest and if I don't enjoy something I tend to lose interest rapidly. Reverse leg curls I could stomach though.You haven't said why you won't do reverse DB lunges.
I had a bad experience a while ago that gave me a strained rotator cuff, as my spotter didn't grab the sixty kilo dumbbells off of me quickly enough on my last set of dumbbell chest presses. Shortly after that I began to strengthen my rotator cuffs using a 5 kilo dumbbell doing 3x10 lying dumbbell internal/external rotations, 3x10 front raises and 3x10 standing internal/external rotations with a cable machine. These rotator cuff strengthening exercises helped me a great deal.Again, the shoulder isolation you are proposing will not help keep your rotator cuff healthy. I'm not sure where you got that idea from, even the traditionally "good" rotator cuff exercises don't include front and side raises. Also, rotator cuff exercises should not be performed in the same way as conventional exercises - going anywhere near high levels of resistance will cause the bigger shoulder muscles to take over.
I'll have a good read up thank you.Read this: http://www.t-nation.com/free_online...formance_repair/pushups_face_pulls_and_shrugs
The most important aspect of shoulder health is shoulder positioning. Generally, people don't have shoulder problems because of a weak rotator cuff (although it plays a part), it's because of over doing "pushing" movements, usually with poor form, along with bad posture. This leaves the internal rotators of the shoulder tight which pulls the shoulder into bad positioning exacerbating the original problem. Catch 22. Yes, prioritising pulling movements and working on your external rotators can help, but once your shoulder complex (including your scapula, or shoulder blade) is out of position the problem is too far gone for this to be sufficient.
I was shrugging between 320-350 kilos with good form with straps. Although my grip and shoulders were getting results my forearms weren't increasing that much and when you have 21 inch arms that looks odd!If you want some good exercises for shoulder health, ask. I don't do any direct work on either. My biceps aren't small and my forearms are pretty big comparatively. Peoples forearms end up small because they don't actually use their grip. The only thing I use straps on is power shrugs, but I'll let myself off considering that I'm bouncing 250+kg around for reps.
More aesthetically pleasing to the eye is my reasoning.Think of it this way. Why would you spend time doing forearm isolation with tiny weights that have no practical use with anything to do with strength, when you could work your forearms for free by using your grip which is actually useful.
Please could you link me to a good romanian deadlift video and a SLDL video? As every video I look at vary in form.Because they work in different ways, and are actually quite different. These, or romanian deads, are the best hamstring exercise going.
It's fine to keep it as long as you think of it as a mass builder only.
Great, but that only makes you strong on the leg press. I have a friend who moves silly weight around on a leg press but squats less than 150kg. I'm not saying don't use a leg press, but it does nothing for your core, so you don't actually get to transfer any of the power of in your legs to do anything useful. I certainly wouldn't go as far as to say it's an exercise only useful in bodybuilding, but it's less useful for strength than the other things I posted.
You need to work your stabiliser muscles. Why do you think that powerlifting or strongman doesn't involve things like leg pressing?
This is why I'm suggesting reverse DB lunges. For a man who's used to working on a smith machine, the shock to your stabilisers will benefit you greatly.
I know, it can seem pretty complicated. It's important to fully understand your goals. When you say you want strength, what does this mean? Do you want to move big numbers on the leg press or bicep curls, or do you mean in terms of more practical usage such as strongman? If you want a bit of mass, then train for it.
I hate you and your super perfect motivation. I need my tunes for that extra Rocky moment.I can't wear earphones in the gym I just get distracted by them - I just get on with it.
I think I am correct in believing, that ideally if you were to do a before work and after work workout, and do both cardio and weights sessions then it can work quite well. I think it is generally best, if you do your cardio session before breakfast, and then your weight session more so in the evening. The biggest benefit of doing cardio before breakfast is your body will be using the fat reserves you built up over night (or any left over carbs), to do the exercises, rather than just drawing straight on the carbs you ate at breakfast. Then obviously you'd top up your energy levels with breakfast to make you nice and perky for the rest of the dayAs said, I may be incorrect, but from my reading, I think this generally is best. I'm not sure if it quite answers your question, but hopefully is some help.
