- 26 Jun 2010
- Hartlepool
I just put a temp sensor off my fan controller on my sticks of ram and the temps never went above 35 so it looks like its to do with cpu mem controller.
yeah as i said it looks like it's inside the cpu because it's under the intel cpu 0I just put a temp sensor off my fan controller on my sticks of ram and the temps never went above 35 so it looks like its to do with cpu mem controller.
http://www.asrock.com/mb/download.asp?Model=Z68 Extreme4 Gen3&o=Win764the USB 3 ports don't seem to be working, I've installed the driver but I don't have any USB 3 External Drives but I assume its backward compatible?
Edit: can someone link the drivers in case I install the wrong ones![]()
yes it can. disable something multimonitor.. can't remember the full name without looking in the biosdid we ever find an answer to whether the onboard graphics could be disabled or not fellas? ta
btw - theres a new L1.15 Beta BIOS out now too![]()
nope that doesn't disable it.It says in the manual something along the lines of if you leave the setting for the amount of memory to allocate for the onboard vga set to auto then if you use a separate vga card it will disable onboard vga, at least thats the way i'm reading it on page 29 .
Can you use on board graphics to run a third monitor with this board (assuming 2 running from discrete GPU)?
To get 4.8GHz and above you'll have to Enable Internal PLL Overvoltage.
Turbo Power Boost Limits to Manual, up Power Limits to 200.
Core Current Limit to 200.
Disable Spread Spectrum.
Set XMP profile for Ram.
CPU Load-Line Calibration to lvl1 or 2.
Use manual voltage till you get your lowest stable vcore, then switch to offset (Offset = Lowest manual vcore - VID).
My disappointments with Bulldozer lead me away to Intel from AMD, after 15 years. I think I know what I doing in terms of overclocking, but this AsRock Z68 Extreme4 Gen3 is something else. Just did my first 8 hour stress test at 4.8 after putting this thing together on Christmas Eve while cooking the turkey. Thanks to the Noctua, it passed with no problems, VCore was at 1.37-1.41volts, temps at peaked at 74 degrees. Now I have to work on reducing Vcore and temps. Having never overclocked an Intel before: is it this easy, or am I just lucky with my purchases?
On the negative side, I have to say the layout of the board's components stinks, there all bunched together in a most unattractive way, blocking access to the on-board LED display and buttons and the Noctua is only 8 millimetres away from the side panel fan, displaying those ugly brown fans to full effect.
