Cheers!
Out of interest how much did your o rings cost?
They were about US$17 and US$2.33 for international shipping from WASD keyboards
Cheers!
argh what to do, what to do.I thought it must be from there. So going by the price you went for the 40A durometer versions.
So you would recommend getting them?
Simply because I miss the numpad. Even the num lock key (used on WoWWhy?
Yes that's right I went for the 40A ones.
If you are like me and bottom out a lot and find it a tad loud then they are worth getting. The o ring dampers do make quite a difference esp. if you bottom out the keys when you are gaming. No more clack clack noise of the plastic hitting the switch.
I still got some left (I left my numpad side unmodded) If you trust me over your details I can mail some out for you to try (about 10ish o rings) so you can see if you like them first before you commit to buying a whole pack.
Just make sure you have a key remover, you don't want to damage your switches.
If you made an effort to look through the thread, I'm sure you would find all your answers.![]()
Just sent you a message via trust.![]()
Yep i received the message. I will mail them off on Monday so hopefully you will get them before Christmas.
hopefully i've made the right decision, cant wait to get my hands on it.
Well i crumbled i got fed up looking and decided if i didnt buy now i'd talk myself out of spending that amount on a bloody keyboard, so i went for the Filco with Cherry Brownshopefully i've made the right decision, cant wait to get my hands on it.
was undecided on red or blue WASD keys so i went with both.
1 x UK Filco Majestouch-2, NKR, Tactile Action Keyboard
1 x Filco, Red ESC Keycap for Cherry MX Switches
1 x Filco Red WASD Keys for Cherry MX Switches
1 x Filco Blue WASD Keys for Cherry MX Switches
2 x Blank, Windows Key, Keycap, for Cherry MX Switches
Many thanks again.![]()
Have you got the key remover tool??? You don't want to end up damaging your switches.
negative, however, looking at the tool i just didnt see the need, it will take 5 minutes to knock something together with bits and bobs i have lying about, it dosnt look like a complicated bit of kitHave you got the key remover tool??? You don't want to end up damaging your switches.
.I've heard this duck noise on four seperate occasions now. Again just a second ago. I cannot figure out where it is coming from and it only started since I got my ducky keyboard =/
got my black widow ultimate today..
lovely keyboard very nice to game on...takes a little while to adjust...
