Yeah I've got both of them things in the basket already and I've been using them =P
Didn't know that! thought it was just a mixture, will change that out for omega 3 then![]()
For doing high weights in deadlifting 1RM mainly and will use the chalk on normal sessions, thought I would pick them up as they were cheap![]()
We already get more than enough omega 6 and 9 from our diets normally, it's the omega 3 we struggle with.
http://www.syncrohealth.co.uk/ use the code "DT500" for £5 off, means you can pick up omega 3 for next to nothing plus you get an extra 10% off any more orders so it gets even cheaper if you make a few orders.
I made 5 yesterday and they've all moved to authorised awaiting packing so seems like they will arrive!![]()
Cost me £2 in total.Keep using the chalk. Missing out on a lift because of sweat sucks balls. Try and refrain from the straps.
Take this guy's advice.
The human body is all about balance. Taking omega 3 helps provide a more balanced ratio of fatty acids, which is extremely important. Give Google a little search, so that you can learn some more about it.[/QUOTE
Got liquid chalk and its great my normal session has improved but it will be another 3-4 weeks before I try a 1rm again.
Also bought a massive tub of omega 3 caps and im taking 6 a day so im getting plenty of it now!
^^Don't forget to make sure the caps have good levels of EPH and SHA in them
DHA and EPA![]()
I made over 12 ordersCost me £2 in total.
