The icon's are from a theme pack:![]()
Your icon looks smaller than it should be. If you have a look at mine, it fills the top and yours doesn't.
Try this one and see if it works:
If it does then you know its your icon thats the problem.
That worked a treat! So obviously it was the icon size that caused the issue.
Do you have a link to where you get your icons from?
Really nice theme's on there. I've gone with Tendance HD as a trial.
Use Springtomise to shrink your icons down to 90% so the notification bubble isnt covered and it looks less cluttered
I find hiding the icon labels also helps which springtomise does.
Ahh Suave bubble......its nice.
Any idea how to remove the dock shelf image in the background?
Please include how to modify the status bar icons in your guide soon!!
Thanks for the time and efforts writing this photoshop, going to enjoy going through and reading it all now the 4S jailbreak is out.![]()
I tried using ifunbox for mac and iPhoneexplorer on mac and I don't get thumbnail previews whilst browsing on the device?
Cant help you there mate, ive never used a mac.
Do you have to install anything on the iPhone?
afc2add from Cydia as stated in first post mate![]()
I have a question. I get two text status bar bubbles either side of my time. one in black and one in green. Using bitesms. Anyone know how to disable one of them?
How do you change the font?
